- Torrance, CA
It will cause scratches to the rim as it doesn't have the advanced non friction surface of professional tooling. To augment this I would mount the tire from the backside of the wheel (while it will still scratch the surface of the wheel it will not be noticable).
Also as with any tire mounting tool you must lubricate the bead while you are mounting it to prevent damage to the bead. I used a solution of dishwashing soap and water and it worked out fine, I used about a 60% water to 40% soap solution but this was a bit strong (it didn't spray easily), the next time I work on it I will most likely use about a 20/80 mixture.
