Bmxpunk1369
- Bridgewater, NJ
i just recently did the H&T by RE and set it up with a 96 cherokee front Driveshaft. I have an 01 with an 8.25 rearend and 231 tcase and it seems as though the new driveshaft is an inch or two short. I am also using 6 degree shims and the angle is still not enough. Can anyone recommend another DS off a truck i could find at a junkyard with 1310 u joints and runs from about 33-36 inches long. The front shaft i used for my SYE is 30-33 and its running with just the tips of the splines exposed and thats on flat ground. I know when it flexes this is going to turn out bad. Anyone have a newer model XJ with an 8.25 and have any problems.
