Root Moose said:I'm missing something...
Why can't you heat it up and bend it into position?
XJawgi said:still no luck w/ the dam tube, were gonna order new tubing and bend our own and use the old fittings.
Redsnake said:not sure if you fixed this yet, but can you just cut the center section of that tubing, get some good high-temp 5/8" hose and clamps and use that and be done w/it.
I had the same problem when replacing headers on my old '94 5.0 Mustang GT long time back... and the fix held up for many miles before being totaled...
5-90 said:Or issue a flexible EGR tube alongside the header. They've got flexible exhaust pipe - had it for years.
I find the EGR of limited utility on the AMC 242 - I actually ran cleaner WITHOUT it in my 87 - but they failed me anyhow (non-functional smog control device.)
Huh? It shouldn't matter HOW it passes, just so it passes, no?
5-90
