Does it have a road name on it? Or a business name? That is most likely a SW1200 but it could be a lot of different switchers. If the exhaust stacks are not capped and the water was not drained from the block properly it is most likely frozen and or cracked and not rebuild able.....but with enough money anything can be fixed! It could be transported by truck, the Baldwins pictured were hauled by truck for about 5 miles through the city streets of Roanoke
You're in luck! The exhaust stacks are capped with large tin cans, and guarded by nests of angry mud dauber wasps and european burrowing wasps. Ask me how I know... :wow:
The oil level is good (checked it, takes 165 gallons of lube), fuel tank is empty as far as I could tell, has a full load of sand, unsure of coolant condition. The air compressor and tanks appear in good condition, the brakes are in poor condition (missing shoes, missing linkages in some cases), some of the axle bearings are looking pretty rough but most are looking OK and still have grease in the pots. The control system has been pretty much trashed by vandals/thieves (probably a dozen or two relays and such are missing, though with a good working knowledge of the design and some spare parts it could easily be reconstructed.) The generator looked OK but I'm not sure. The batteries are all missing, I think they were removed when it was decommissioned because the cables are neatly placed in the tray instead of being cut off. The motors are disconnected as I think I said before, but that's as simple as figuring out which of the four wires go where and reconnecting the links, then clamping the insulators back on... they were not damaged as far as I can tell.
The rail line's logo looks like a vertically elongated B with something else crossing it at the center horizontally, I'm not sure what. It was painted over, I need to see if I can find the name of the owner of the tracks/former line name, it goes through Greenfield NH from Nashua NH.
EDIT: Looks like it might have been part of the Milford-Bennington Railroad, and/or Boston & Maine. The section of track it's on was bought by the state of NH to preserve it for future use back when it was abandoned, and was used from 2003 to 2005 as part of the Wilton Scenic Railroad, though the engine in question was not ever used for this venture.
EDIT2: The logo (painted over) is DEFINITELY the old B&M logo - vertically stretched B crossing a horizontally stretched M.
EDIT3: it was previously road number 1228, then became 1423. Neither is listed on
http://www.northeast.railfan.net/bm.html
EDIT4: found it! search on page for 1423
http://home.comcast.net/~railimages/bmros2.htm -
http://en.wikipedia.org/wiki/EMD_SW9
