Trail Ready
- Cerritos ca
Unfortunately I have to sells Xj due to some unexpected things popping up.
It's a green 94'xj 4 door auto with about 240k
4.5"RE lift with 1.50" coil spacers
Bilstein 5100 all around
Crown extended brake lines
RE gen 2 discos
Black steelies with Pro Comp muds(5) with about 30% tread or so
Brand new WebDog winch bumper and brush guard
Brand new Warn M8000 winch that has only had 5'of cable unspooled literally.
231 xfer case
Stock d30 and 8.25 axles
Aluminum radiator/water pump/t stat and fan clutch installed about 1 year ago
Headliner re upholstered
Interior is a little dirty but no rips
Body is straight besides a dent in pass rear door
Paints a bit faded
** now the bad**
I recently bought a re built Durango steering box and bracket but while installing it my brother in law broke the power steering reservoir and needs to be replaced and have the steering box re installed.I do have the reservoir tank,Durango box and bracket but do not have time to installing it so you will either need to have it towed home or you can fix it here and drive it away that's why I am asking $3000 firm.
I will post pics soon.
RE gen 2 discos
231 xfer case
Paints a bit faded
** now the bad**
