- Indiana-Missouri
you haven't seen it after the 2nd chop, its almost hard to look at.
Beezil said:you haven't seen it after the 2nd chop, its almost hard to look at.
Beezil said:Kacz.
edit:
also, I am having trouble determining where the CG is.....my rig is WAY lighter in the rear, has heavy fullwidth axles, big tires, and no a ton of lift relatively speaking. I'm not sure if I can use the theoretical CG that everyone puts right behind the top bellhousing bolts.
Ed A. Stevens said:The 70% answer.....(insert lots of kick ass tech)... rack & pinion system.
Goatman said:Steve, what do you figure is a perfect suspension? I guess that would have to depend on what you want it to do for you. I always figure that since we're not building rock buggies, our suspensions need to do many things well. Good on the street, good at a reasonable speed on rough roads, decent flex, good climbing ability, and stable in off camber situations. Perfect will be at least some compromise between the various things that you want it to do for you, leaning towards your own personal priorities. I'm curious about what you're after so I can watch as it comes together for you.
Link price just went up huh?Beezil said:willis you jackazz!!!!
Ya, he'll be on you like rice on a Honda.we were trying not to let eagle find out, remember?
Trailer tire, steal one off of one of those great single wides in SlickRock?besides, didn't I make it clear that I had an "adequate spare"?
never mind the fact that it was a trailer tire, I considered it "adequate", just like the bylaws state.
Great idea. I think I'll hit the can. That's where I do my best thinking.BTW, what I do with ed's posts, is I print them out, I leave the computer room and sit on the couch, and begin to read.....slowly.....rinse and repeat.
Been there, done that. That's what got me thinking about the 'correct' geometry of the front. Yes, it's all your fault.if you do a search on 4-links, you'll find a long one I started a while back, and there's some really great info there....
have a look.
Willis said:The NorthWest is hilly, muddy, rocky and narrow. Maneuverability and control are my biggest concerns. I also need good street-ability, as it will not be daily driven, but will drive to and from Moab, no trailer in my immediate future.
I want my lower to mount directly behind my axle, but 8.75" above that, puts my upper pretty close to my pan, if not into it at full compression. So, the lower needs to be mounted lower, so the uppers are not so high. I want my lower arms at around 7*. Well, with a 33" long arm, at 7*, my arm is around 3" below my framerail, which I suppose is not too bad, I just wanted more clearance.
Steve
That puts my separation at 8.75
If you think a buggy is a blank sheet, think again. The new buggy is a PITA and it started as a clean sheet
Beezil said:Kacz.
here's a quick drawing....
Sweet, back on topic!
B-Thanks for the pic. I'm suprised to see the profile of our rear links looks very similar. It will be interesting to see how much more body roll and rear steer I get by only triangulating the uppers (assuming the rig ever gets some action).
Did you ever consider shortening the wishbone in order to help clear any of the obstacles underneath? Right now, mine may end up being a mid-arm (~26-28") four link.
-Jon
Grant said:A quick question for the real Engineer's now.
Front suspension only. Buggy not XJ.
What roll center differences are there between the following?
Example 1 - Double triangulated 4 link, upper links narrow to a common point on the top of the front axle, lowers slightly splayed outwards from frame to axle
vs
Example 2 - Same setup but lower links converge, and upper links splay out.
Basically if you used Beezil's existing setup, and compared it to the same setup, but with the parabolic link located low and splayed links located high (ignore packaging problems)
Am I correct that AS stays constant, as upper and lower link angles remain unchanged? Am I correct that RC is now lower? Why?
Typical damn South African's - bash the Engineers in one post and then ask their advice in the next. Hypocrite
Beezil said:if you say "behind the axle at the center-line" and still want 8.75" of vertical seperation.....that doesn't leave a ton of room for you to compress without punching a really serious, and buzz-killing hole in the bottom of your oil pan....but, maybe your design allows for this?
you need to spend a couple hours under your rig on a comfortable creeper, with some sage incense buring, candles lit as mood lighting, a pot of green tea going, and some mystical ambient music playing in the backround.
Also, the 3" under the framerail mount that Goatman describes is a spot I plan on playing with
Beezil said:I really really really really really think this is a bad idea.
I'm 1.75" under the frame rail at my lowest point, with 37" tires.
You are gonna HANG like a horse theif with a 3" rock snagger on 35's....
Doing so might make the numbers look good, but at the cost of getting DENIED on trail.....
once you hear the terrifying sound of goatmans evil snicker as he's lifting your jeep by your rockrails with the highlift and throwing you tow straps, you'll never get it out of your head, and you'll have the nightmares to look forward to.
