squareone97
- NV
Hello,
I have a 99 XJ sport 4.0 4x4 auto. All stock. I have 2 issues that might be related to each other that I've been trying deal with since i purchased it a few months ago.
#1 vibration (pretty sure from front) from 60-75. Feels like u-joints or tires. changes a bit with engine load.
#2 loud metallic chatter while turning left. Definitely from front driver side. Only present while turning left sharp enough to get weight transfer off the driver side.
work done to try and solve these issues/ needed done anyways:
upper/lower control arms
New tires
new front rotors/pads
All u-joints-- front axles as well as drive shafts
Motor/trans mounts
front wheel hubs
pulled the front driveshaft with no change.
this up coming week I'm going to change the fluid in both differentials as well as look for any internal issues. anything specific I should check?
Any ideas on the issues I'm having? I've tried everything I could think of.
Thanks!!
New tires
Motor/trans mounts
front wheel hubs
Thanks!!
