Only In A Jeep XJ
- Greenville, Texas
How much lift is too much when running a front drive shaft in the rear.
x2, 6ish and mine is working out fineILLXJ said:I'm running 6" with no problems. JIM.
XJRunner said:I was told that If I run a front driveshaft in the rear it would break as its not strong enough?
outlander said:You want one from a auto tranny equipped xj 87-96's a safe bet....
It also depends on what rear axle you have.d-35's yoke sticks out about 1/2" less than a d-44 or 8.25
In my situation with a re 5.5" lift,5speed tranny,and d-35 rear,the front ds from an auto xj was about 2" too short for me...had to have it lengthened at a driveline shop.
btw its the auto tranny itself thats longer compared to a 5speed not the t-case....
MrShaft696 said:From all I have seen and tried.... If you have a manual trans xj a front shaft is at least 2in too short to run safely, it cost me around 90.00 to have it lengthened. I pulled a front shaft from a 94 and it bolted right up to my 96 with a PORC SYE.
IslanderOffRoad said:I'm running a 5spd, have an 8.8 waiting to go in, and bought the PORC SYE. Will the front shaft still be too short for me? I'm running 3.5" of lift.
