beastlydumass
- norfolk, va
ok so when i got the heep the kid had hit some thing and pushed in the passenger front side frame and ive also had to recently cut a piece out of the front cross member do to a bad nite chain hook up. im wanting to just cut out the outer side and weld in a nice solid sheet of steel but not sure if there will be a problem after i cut it out before i can get the sheet in or if ill have a problem welding sheet steel to thin unibody.
you can see on the left that the mounting holes are jacked up to and can only mount the bumper with one bolt on that side.
mini sledge help beat it in alitle after this
not to worried about the inner frame not bothering anything
