brotherwes
- Arkansas
Quoting the Ford guys...
From < http://www.therangerstation.com/tech_library/4wd_Front_Axles.html > bottom of page:
"Things To Watch:
Bearings - Ranger TTB axles are known for bearing problems (particularly when using wide-offset wheels). You should keep a close watch on your wheel bearings to make sure they haven't loosened up or become damaged from overheating. If you wheel your Ranger and carry spare parts you'll probably want to carry a spare hub and wheel bearings. The stock hubs are prone to break from hard wheeling and the wheel bearings could go out on you somewhere between the trail and home due to debris, heat and working their way loose. Loosening of the bearings can be minimized by torquing the outer bearing locknut to 225 ft-lbs instead of the book spec of 150. "
