Ford 9" currie third member, 2 detroit lockers, gears, housings, shafts, etc.
Vanimal
escondido, ca
A friend of mine is clearing out all his nascar stuff. He has a currie 9" third member with 4.63's and a 31 spline detroit, set up and ready to go. $700
a separate detroit locker, 31 spline. $250
gearing in these ratios. Probably all used for a race or two each. $50 each:
5.29
4.71
7.33
7.16
6.50
4.78
6.33
5.50
4.63
5.43
We also have a full float 9" housing with shafts and hubs. Brembo or Willwood brakes available. May have a degree or so of camber built it (Nascar stuff). Make offers. Should be about xj width.
Bare unused 9" stamped center section, ready for you to weld your tubes in. Make offer.
Spare 31 spline full float shafts for the above axle. Make offer.
Brembo and willwood front and rear calipers. prices range from 250-500 a pair. The brembo calipers are really high end, titanium pistons and billet cnc machined housings. A full set of these retail for $15k new with rotors (we have rotors but they're 5x5 lug pattern).
http://www.rogueengineering.com/bmw/b.html
