- Roanoke VA
sorry to hijack
while in the subject of overheating etc. tell me would a cracked outlet have reason to lower my mileage to 10.5 mpg or 4.5 km/l (as we use here). this running highway at around 65mph. i have had the vehicle at the agents and to no avail. my xj does seem to run slightly warm as well. it is a '96 4.0. the cat has been removed some time back and have done a barrel air filter conversion. i run on 30's so i can't see this having such an influence.
any help will be very much appreciated. where can i start looking. any sites will help.
thanx
steve
Yes, the influx of fresh air at the exhaust manifold causes the O2 to read lean which in turn will richen the air/fuel ratio to try to achieve what is required. I have had good luck welding the manifolds in the Jeep, you may have to remove a few things so you can get to the crack to put a bead on it though.
Are you getting a CEL after removing the cat. In my experience with OBD2 you will get a "catylist below threshold" code, PO420 or something like that.
