bobinyelm
- Waxahachie, TX
Given the weight, engine size, and the gearing of our Cherokees, the fuel economy generally SUCKS.
I've put up with it to date in my '01 XZ w/4.0, AW4, 3.55 dif, but with gas $3.25 a gallon, I am tempted to actually do something about it.
Some folks seem to get up to 25mpg highway (conservative driving) w/ their XJs, while others are fortunate to get 18-20. I drive like the proverbial old fart and only manage 20mpg around town or on the highway (60mph cruise), but a vehicle w/ Cherokee's stats (3100 pound empty weight, 3.55 gearing w/ OD and locking torque converter) SHOULD do 22-24mpg easily highway.
4mpg doesn't sound like a big deal, but over 20,000mi/yr it's OVER $500 in fuel savings.
I have a '00 TJ (4.0, 5spd, 3.73 gears) that I replaced the O2 sensor in (because every few months it would throw an O2 code), and BEFORE replacement, it ran GREAT and got 25mpg. With a shiny new O2 sensor, driving the SAME way, I can only get 20mpg.
I have a feeling that given the better gearing and aerodynamics of Cherokee over Wrangler, 25mpg is a realistic goal in very conservative driving, and think that if that "bad" O2 could get 25 in the TJ, a MODIFIED O2 circuit or MAF circuit can do the same in the XJ.
Getting 25mpg didn't hurt a thing in my TJ, so I see no reason "tuning" an XJ to do the same could hurt anything in an XJ.
Anyone done or familiar w/ a way to "fool" our computers to lean the mixture slightly? Maybe an Op AMP to increase the O2 output slightly so that when the exhaust actually produces (say) 0.45v (which is the nominal target voltage), the circuit actually SEES (say) 0.50v so the computer will further lean until the computer sees 0.45v (which would mean the ACTUAL O2 output is 0.40v, or leaner than target)?
I have heard of tunable MAFs, or fuel pressure regulators, but given the authority the O2 has over the entire operation, I wouldn't think a modified MAF or fuel pressure would change much (since the O2 circuit would just change the injector pulse width to compensate.
I don't want to eliminate the closed-loop fuel control-I want to MODIFY it so I can perhaps select (with a potentiometer) a certain mixture target and have the computer use THAT value (rather than 0.45v or 14.7 air/fuel ratio). This would give me the option of returning to a richer mixture if I were towing, or a leaner one when it might be appropriate. I naturally have no desire to burn a piston or a valve to save a few bucks on fuel.
Bob
Bob
