crazymoose1990
- Beavertown
When I had a roller fairlead I would use that depending on direction. When I lived in Cali my friend had an old frame machine they also work great.
Thanks for the input. I was thinking about going to a 32 when I get another tire and maybe trimming a bit but 32 is where I'll stop with the tires and this isn't going to change till next year sometime. This is going to be my driver. So it sounds like your preference would put the 32 right in the middle of what you like for gearing. 3.73 for a 31 and 4.10 for a 33? I need to decide on something though because I'd like to do it in the next few months. Who is doing good work these days?
Any thoughts on the front not flexing quite like I thought it would.
I had a question about upper control arms also. I haven't done anything with the ones on it now but am going to. Should I go with just a bushing replacement or possibly a zj adjustable upper or something more substantial?
Thanks in advance...
If on an auto maybe, on the 5 spd its totaly different
Got my lights yesterday.
Hella H4 E-Codes
Osram 85/80 bulbs
Relayed wiring harness
It turned out to be a smooth install. Took just over an hour but the harness came with the high and low beam wires mixed up. Fixed that today and looking forward to seeing the difference tonight. Here are a few pictures.
These are the Wagoners that were in it. The buckets are 25' apart and the wall of the building is 180' from the front of the jeep.
This is the E-codes with the wiring mixed up so the comparison isn't low to low. New lights are AMAZING!
