UndrTheInfleunce
- Tucson, AZ
Hey guys, i have some worked spider gears im replacing and im having problems taking apart other differentials to get the spider gears out. Maybe you can help me out.
The problem starts right after i open the differential casing. I try to pull out the pin that holds the larger cylinder that the smaller gears spin on. The thing is on mine it was a small hex head bolt in there. In these other cherokees at the junkyard im trying to pull some from they have some kind of weird pin with a small gap in it the length of the pin. I couldnt figure out how to get it out. I did notice a small hole on the other side of the pin hole but i couldnt tap the pin out or wrench it out at all.
does anyone have any advice???
Brad
Brad
