Cottontail
Three-De Off-Road
- Nashville, TN
2001 XJ...3.5" lift....
Engine light just decided to come on today...and stay on.
It is at 14 volts, running at 210 degrees. The oil is full, as is the coolant reservoir. The oil pressure was at 50 during accelleration, down to 35ish during idle in gear, and at 20 during idle in park.
At first glance I can't find anything to cause this. I did notice that my auxiliary fan is coming on, what I would consider, excessively. As well, the engine always "smells" hot, like hot oil for an hour after I shut it down.
I did notice oil on the bottom of the throttle body as well as on the inner fender well "ledge" behind the air cleaner box, and on the "ledge" under the steering box.
Yesterday, I also noticed a fairly large "thunk" coming from, what feels like, under my feet or the transmission tunnel. It is most obvious on turns (L or R..doesn't matter) and during accelleration (straight or in corners), most obvious between 20-30 mph. Can't really feel it when I hit 40. Will notice it again if I am at 40 and begin breaking (especially on a straight away). I really don't think that this has anything to do with the engine light, but I could be wrong.
Again, at first glance, I checked all the components of my drive line and lift and nothing seems to be out of place, loose, dented, or misaligned. The only bolt I found loose was one of the rear shock bolts had worked itself loose and had no nut on it.
Anyway, would appreciate thoughts. I am going to a SEC meet and greet this weekend about 30 miles from the house, so I am hoping someone there will have a code reader for the engine light.
Thanks!
Thanks!
