I need some help identifying some connectors under the dash.
Its a transplanted harness from a 1991 XJ into an 87 MJ.
Black connector, 4 pin (heavy gauge wire)
yellow plug, coming from steering column.
White 2 pin connector (Wh/Bk goes to fuse panel, Wh/Pk goes to break switch, va an adapter)
Black connector, 4 hole, with 3 wires
Blue connector (fits the break switch too, but is not connected)
And if anyone knows, what is the "red" relay?
Thanks!
Thanks!
