sidriptide
nobody of any consequence
- western massachusetts
i have an electric fuel pump to feed the carb in my CJ rather than the mechanical one. it is the typical electric pump with a flat bottom with the ports to each side and the motor above it..
is there any reason i cant mount this "upside down" with the motor below the pump housing? i dont see why not, so i'll give it a shot.
i had it mounted on the inside of the frame rail in the normal way, but i'm moving it outside of the frame rail in the same location and it would make life easier if i can just "flip it in it's bracket.
thanks!!
thanks!!
