mojojojo
- Gresham, Oregon
Heres the back ground:
this is a 1990 limited,
i recently did the OBA conversion. i tried to rip out as much useless stuff as possible. one of which was the low pressure switch for the a/c. well i have since figured out that this was the connection that made my electric fan work (oops). so to remedy this i ran the 2 wires that went to the low pressure switch to a regular toggle switch. i used it one time on a trail run and it worked fine. did a lil re-wiring of some lights and stuff this weekend and all i did was unplug and move the switch and now i have a blown blower fuse ?
so my questions are. . .
1. did i go about the switch thing the wrong way ?
2. if i did, and should run a straight switch & relay directly to the fan, will this effect anything else in the a/c & fan electrical system ? (by not having a complete loop where the pressure switch used to be)
3. was i correct the way i did it and just had bad luck when i was poking around in there this weekend ?
thanks for any help. just need some piece of mind before i replace that fuse.
Rod (mojo)
Rod (mojo)
