I just re-geared to 4.56 about 3 weeks ago and have about 300 miles on it with easy driving no high load. About the middle of last week I noticed a vibration around 30-35mph. It gets stronger as speed increases, but is not accel/deccel dependent(it is speed based not throttle based). I tossed it up as a bad u joint. I ended up replacing it this weekend. Now the vibration is worse. I did some searches and found a couple threads stating it could be the pinion nut has come loose. I have rechecked both pinions and they are nice and tight. I do not have a sye. I do have a tc drop though.
It is just weird that it would develop randomly when everything seemed fine.
Also I checked for axel wrap last night. There is little movement from the axel when power is applied forward and reverse. An motor & trans. mounts were replaced about 4 months ago. They do not have any cracks or tears in them either.
My plan of attack:
1. Remove front/rear ds to figure out which end it is coming from.
2. check u joints in front ds for play/slop
3. use gauge to check actual pinion angles.
Any other suggestions of what to check next or first?
My plan of attack:
