Badmunky
- South east Michigan. (For now)
Ok so I have a problem with my drive belt slipping.
I know why its doing it. But am not sure how to go about fixing it.
The problem is that the last owner parked the Jeep for almost a year.
And all the pulleys rusted. I did my best to clean them with a wire brush. But I do not drive this Jeep every day as its mostly just a wheeling toy.
I have tightened the belt as much as I can without causing problems. But it is still slipping and squealing.
Every time it starts slipping my voltage drops, my temp starts climbing, and I lose my power steering. If I turn the A/C on that will guarantee it will start slipping.
I plan to replace the clutch fan with an E-fan soon, as the clutch is failing. And will be changing the belt again do to needing a shorter belt. So I want to fix the problem at the same time.
So what can I do short of removing every pulley and dipping it in rust remover?
And what can I do to prevent this from coming back later?
Thanks guys!
Pic of my Jeep just because JEEP! :viking:
Thanks guys!
