Door Lock Cylinder Rod Linkage Missing
99SGCS
Iowa
Hello,
Just got a 99 XJ 4 door and the drivers door lock cylinder was missing. I picked up an OEM replacement and when I went to install it I found that the cylinder linkage rod is missing. I checked along the bottom of the door and found the old C-clip but no linkage rod. I'm not very good with Google, but did try a search and have not found a replacement linkage rod. Any ideas where I can find a replacement?
I still need to replace the passenger side door lock cylinder (it's seized up) so bending a piece of steel rod to shape is an option, but not my preferred course of action.
Thanks.
Here's the part numbers, but you're not going to find a new one. Best bet is junkyard, someone local parting out an XJ, or bend up a new one using the right side as a mirror template.
LINK, Key Cylinder to Latch. 1997 - 2001
Left 55076047
Right 55076046
Thanks, lawsoncl, that's what I was afraid of. Down side of owning an almost-classic vehicle I guess. Lets hope my fab skills are better than my Google skills.
