Thanks G. Appreciate the comments and pic. The vac pic did help.
(FYI, I have been an auto tech most of my life... so I am good-to-go (if not rusty), but certainly worth posting the tip).
Sooooo, anyhoooo. Today, spent the morning in the hot sun gathering parts. Spent the day installing, un-mucking up the vac system and other stuff, installed O2 as outlined above. Decided I had enough time to go try emissions a 2d time. Off I go.
(note to self: even though I am 6 foot 1 in tall, I need a small ladder to service this engine)
Hit I-40 to get things up to temp, then drive to testing station. No line, great! Roll in, help the short guys open the hood, they hook up everything, run the test. They get to the last step... the gas cap test. IT FAILED!!! WTF, the cap passed yesterday. He runs the cap test 3 times, no dice. Failed because of the cap. But the engine is running great.
Off to buy a new gas cap. Come back & pull in. Same thing, hook it all up and test everything again. We get to the gas cap, hand him the new one in package, it passes. Woooooo Hooooo. 3rd time is a charm.
Just got back from DMV. Title, registration and plate in hand. Long day.
Below are the results of the test. Mo betta.
Did you put the existing EGR on a vacuum pump? If it's idling and you apply vacuum it should change the idle. Also the EGR should move (you can see the actuator arm) when you apply vacuum and hold said vacuum. If it's not doing that it probably won't pass.
