austinaubinoe
- Montgomery County, MD
Hey so I picked up a cheap OBD1 1994 Jeep W/ a 4.0. Been trying to figure out the issues as it cranks but does not run. I bought it from my buddy after it randomly left him stranded.
Today I was cranking it then thought about how I never considered fuel to be the problem. So I left the key in the ON position and went to depress the schrader valve on the fuel rail.... no fuel squirts out. Had my sister sit in the jeep and turn it on.... fuel pump does not prime. pulled the fuel pump relay....not burnt or melted.
However, when I put fuel in the throttle body it did not fire. I just replaced the cap/ rotor and spark plugs. How can I tell if my ignition system is not working at all? It has 186,xxx miles, so could the coil be bad?
Thanks.
Thanks.
