HaleYes
- Clay County, IL
Nope. I just use a cheapo cardboard gasket on my 8.8.Do you guy's have any problems getting the RuffStuff covers to seal?
just used silicone on mine with no gasket and its holding up fine.Do you guy's have any problems getting the RuffStuff covers to seal?
my rusty'shd steering will hit the ruff stuff cover at full turn in both directions. but going otk might give you a little more clearance.I have a Ruff stuff on the back on my 44, but im wondering because I just put Oneton, OTK steering will a ruff stuff cover fit the front 30?
You guy's convinced me. I went ahead and ordered the RS diff covers. I can't wait to get em.:guitar:
Two things that the RS cover has over the Riddler, 1) counter sunk holes to help reduce ring gear deflection 2) no drain plug option which helps reduce maintenance time. A third thing would be if (and thats a big "IF"), you ever did gash the cover you could easily weld it up since it is steel instead of cast.
I do recommend Lube Locker gaskets with either of these covers to prevent seepage of lube, RTV will not get the job done for long.
Question; how do countersunk holes reduce ring gear deflection over regular bolts? Riddler, RuffStuff, BTF, etc, will reduce deflection due to the thickness compared to a stock thin cover. Countersunk holes are just nice to have.
RTV seals just fine, LubeLockers are nice though but not necessary. -B
With the thickness of the cover and 10 countersunk holes helping to hold the cover snug in place, the cover becomes one with the diff housing helping to prevent the housing from distorting under load thus keeping the ring gear in line with the pinion. Non- countersunk holes are OK but the countersunk holes help to keep the cover from shifting any in a load situation.
I always thought the counter sunk holes were there when u hit rocks, it didnt strip the head of the bolt out..
Anyhow.
I just cracked my housing on the bottom of my D30 when i landed on a rock (spotters falut) The RS cover was still perfect. I even put it back on my other axle. I would say its the only piece that hasn't broke on my heep yet....lol FYI It works with ORO U-turn steering.
by having a tapered Allen counter sunk hole it is believed to allow any movement the cover may see from the tolerances needed in the mounting holes since the cover is not threaded.
I like the idea that if you need even more protection you can weld (a lot easier) on extra "panels" onto the cover since its not cast. I think its Blue Torch Fab or some other diff company that does this that ends up with over 1/2 of steel around the middle and the bottom of the cover. they did a shoot out (quite literally took a gun to the covers) and I think the cover took quite a few shots from a high power rifle and a .45 Mag and just dented the cover, with that kind of "modification"
