While I contemplate selling the bucket of bolts, I might as well give a mini build thread. How ironic that I do it now.
When I got it, it was a total mess. I did extensive metal repair with the good Omix ADA metal replacements and did the underside in bed liner for protection of that nice new metal. I also hit the thing with some OD paint for the Mad Max effect. Here's a few pics:
Omix Metal replacement
Jeep Pic Side
Jeep Pic Front
Under Side
Floor
I got a nice dual 10" fan kit from Jegs. It's relay'd to come on at 180. I retained the stock radiator. I hate the way my coolant pipes route.
Fan Kit
I hated the idea of running a Mercedes oil cooler long term. I had the fittings converted to AN and ran a really nice 10 AN cooler with stainless line.
Oil Cooler
Oil Cooler Fittings
I also have a throttle position sensor rigged on the valve cover for the AW4, which is retained in the swap. I don't have pics of this yet uploaded.
XJs have a 20 gallon tank stock and early ones have a nice easy to access port. I dropped the tank, cleaned it out, and let it fully dry. I swapped out the pump for some simple fuel line. I then ran all new fuel line and removed the stock filter. I reused the factory hard lines as well for a nice clean look. It turned out well. I run a small filter up near the motor. Fuel gauge works.
So there you have it. That's the XJ now pouting in my garage...
If you are interested, shoot me an offer. The worst I can say is no. If you have a stock XJ, and want to do an OM617 swap, lemme know. This can save you countless hours of labor lol. If I get a decent offer, I'll sell it. If not, I'll fix it. I'm rather bummed out about it right now to say the least..
More pics by request:
Link to bunch of Pics
