Mitchen
- Gresham, OR
the 8.25 is fine through 35's. go 8.8 if youwant discs or plan on going bigger than 35's. otherwise leave the 8.25.
the 30 is plenty strong.
but if you are getting a 410 front, do you have a geared rear to go in too???
i have climbed a lot of stuff where my front tires have barely been touching the ground. so a front locker woulda done jackshit. the front locker does help you break over the crest more than the rear locker would, but without the rear most rigs couldnt get to the position to climb in the first place.
REAR locker FTW
oh and if you decide to lock the front and havent upgraded your steering yet, carry lots of spares
the biggest i would ever probably plan on running is 35's but that would not be any time soon.
i need to either find a used 8.25 29 spline carrier and a set of 4.10's or order them.
the front axle isnt going in until i rebuild it completely and get the locker in and the rear matching gears.
i can see how front - rear, both have there positives and negatives. but i think i will be happy with the lockright this summer until i can get the rear Detroit.
if i ever step up to 35's i would probably consider getting a 44/ARB
