northwestxj
NAXJA Member #1283
- washington
I heard that a steering damper just masks the problem and DW will come back
yep, it's like a band aid. If everything is setup right you shouldn't need to have it.
Why I still think that one needs a steering damper is because everything on my front suspension was replaced with new stuff when I did the WJ knuckles - even my diff was swapped out with a HP D30 as part of the process and I fitted new adjustable upper and lower control arms.
If it IS true that a steering damper is only a nice to have and not a neccesity and I have to go search for something that might be causing my DW without steering damper there might be three possibilities I can think of. One is I've noticed at about 80km/h sometimes I get a slight wobble through my steering wheel as if a wheel is out of balance (even though they are balanced) - I had this prior to the WJ knuckle swap as well. Second is I know I have a very slight buckle on my right rear wheel (think the side shaft might be slightly bent) and third is that I'm running short arms on a 6" lift in the stock position which I know isn't ideal and I'll most likely fix it with drop brackets.
Agreed something else is wrongNo it doesnt. Bad angles don't cause deathwobble, just bumpsteer.
Something else is wrong.
I've got death wobble on my '88 MJ now. First happened around 75mph when I hit a bump and it has gradually worked it's way down to where it will start at 60mph without even hitting a bump. I had this once before about 8 years ago on an XJ and it was solved with aftermarket LCA's, I presume to fix the caster angle. This time around I have a 2" lift with RE Super Flex LCA's & stock UCA's. The steering stabilizer is now shot, but I think that's a result of the DW, not the cause. It was a new pro-comp unit a year ago. My inner c's lean back at 8.6* and I have no toe-in or toe-out after doing a rough measurement. I haven't found any loose joints yet but I'll keep checking. Can too much caster cause a problem? IIRC most rigs run 5-6* of caster.
Ballance the tires that could be the problem right there.
