Hellbent
- san diego, california
I meant the long soda straw that runs to the driver's side knuckle.
I've used the v8 zj tie rod stuff a couple times, but I never bothered with the drag link and it's adjuster, as it appeared to be identical to the xj stuff.
ZJ uses the same ES2079S stamped adjuster sleeve (or did you mean the long hollow TRE?). I've been trying to convince a vendor to make solid metal adjuster sleeve to replace the ES2079S, maybe something will happen. That and the ZJ tie rod would be golden for a DD with light trail use.
