- Port Orchard, WA
you my firend are spitting more BS than you even know
what about the case for the higher gears?
did you do new brake components?
what about u-joints in the shafts?
what about driveshaft length?
what about Axle seals?
wheel bearings?
Misc hardware that you didnt keep track of?
come on - you know you spent at least 800 on it once you add all the nickle and dimes togehter...
xjaddiction said:If you want to scrap the 5 link and switch to leaf springs you can do it for a grand.
Here are my costs, and I know they aren't that unheard of;
-spring pad perches $20
-Leaf springs from 4" YJ Free
-2 inch YJ Confer Shackles Free
-I have a steel aftermarket front bumper that I welded to, you can make a cross-member and use the stock front bumper too.
-Dana 44 from '86 grand Wag d-side drop junk yard $66
-5:13 gears about $150
-Lock-rite about $250
-Warn Hubs $75
-E-350 Master Cylinder $12 from Junk yard
-Steering is waggy and ZJ mixed parts with a bent waggy Drag link (yes it sucks with bump steer, but you could drive with it till you got the high steer)
Total for me= about $550
wheel bearings?
