- West Sacramento, CA
So how bent is that housing after putting all that heat into it, with split tubing sleeves?
The only way I know of to tell if the axle is warped would be to put a very straight pipe down through the axle tube and look for deflections at the the ends. Finding a piece of pipe that straight and that wont deflect is going to be the hard part.
Anyone else have an idea on how to check straightness of the axle?
John
I didn't sleeve my 30 but I trussed it, installed some cryoed Yukon 4.88's, full case Detroit, RCV's and that was 4 years ago. I beat this axle to h3ll and back. I have ripped all the teeth off the ring gear once(that is why they are cryoed now) and that was the only issue.
That is the mother of all 30's!
I still argue it's way too much money and work to end up with an axle that's still weaker than a stock 60. I made the mistake of a polished 30 and the stripped ring and pinion were the last straw for me. Yes, a 60 has less clearance, but it's strong enough to drag it around.
I'm on board with building it.
If you require a dana 60 to not break, you shouldn't be wheeling.
I like how you used u bolt plates as LCA skids. Very simple solution!
I don't require a 60 to not break, but it's cheaper and stronger than this type of ultra 30 build. If you have to be light on the skinny pedal after dumping this kind of money and time into your front axle, maybe you shouldn't be wheeling?
