Ya, i'm getting new gears. I dunno what year tractor it was, the guy just said it was out of an off-road scissor lift, never been used just sat outside for a year or so. Its an auto, but I thought about keeping the 7.17 for a bit but I wouldn't be able to put it in 4wd...
If you are going to do new gears... my advice is do it before you put the axle in. It is MUCH easier to do on a workbench or jack stands than laying under your truck.
As far as putting it on yout Jeep:
I used TNT U-Bolt Eliminators because I wanted an extra inch of lift, a wheelbase stretch and liked the bump stop portion. Ruff Stuff Specialties has some nice weld on perches, too, if you want normal u-bolt type perches.
If you keep the axle in it's stock location, you will need a shorter drive shaft (or get yours shortened).
Since I was using a relatively new drive shaft, and didn't want to deal with replacing my SYE, I bought a 1310 yoke for the 60 so it would fit my u-joints. I figured I'd try this size and if it becomes a breakage problem, I'd switch to a larger ujoint and drive shaft later.
Maybe I missed... what are you doing for brakes? I did a disc conversion on my FF60 and got rid of those monstrously heavy drums that came on it. You need to know if it is a Ford or GM axle to get the correct bracket. The BOM search listed above will tell you that. The conversion bracket is pretty cheap (
www.greatlakeoffroad.com), then you use 85ish GM front calipers and rotors (I used 8 lug 3/4 ton parts). Calipers are less than $20 new from autoZone (with a core exchange).
Here's a bunch of pictures from the axle build if it helps you....
http://s224.photobucket.com/albums/dd20/swillier/Jeep 3-0/Dana 60 FF Build/
Here's the brake conversion:
Hope this helps...
