98GrnMachine said:Would you still have to worry about vibes and eventually require an SYE and CV driveshaft to go with it? I don't mean to highjack, but I'm currently dealing with the same dilemma. I'm installing a 44 and going to 5.5 on a '98 which will in all likely hood need a SYE.
Goatman said:Yep, that's what we all do. With a little lift the slightly longer D44 pinion makes the driveshaft work perfectly.
ryan said:I have seen this same debate in other threads and when I set out to do the swap, I was under the impression that my D35 shaft would work. Not the case, I think it depends on the tranny t/case combo.
