CORE 4WD
- virginia beach va
My rails are basically the same as diagramed previously. They go from flare to flare and use 1/4" x 3" angle at the unibody vice just a plate on one side of unibody, which some companies out there use. Also uses full-length on pinch seam. I used 1/4" plate to fully cover from front to back and rail to unibody and cut out two areas for Hi-lift just inside of rail. It's tested (Crozet Va) with full-weight drops on rail and works great to slide over rocks from front tire to back tire. Does not flex, is spaced 1/8" inch from rocker with no damage. Hi-lift tested, no flex. Plate slider is bolt on as well. If you want pics e mail me and I'll send you some. core4wd@cox,net My 2 cents...
