ECKSJAY
Water is dirty
- Covington, WA
xjaddiction said:I'm using an RE adj tracbar with drop bracket, Tereflex adj upper and lower CA's, RE CA drop brackets, and a ZJ pitman with the Currie steering. I also have barpin eliminator kit on the shocks. This gives me plenty of flex. So much that after the run I took above pic on, I bent the down tube(from the header to flange) on the exaust enough to loosen the flange bolts. With that much flex, the front d-shaft hits the exhaust. Prior to the Currie set-up (I've had all the other stuff for a year or more), I didn't flex enough to bend the exhaust.
Greddy
Cool, hehe. What shocks are you running? I've got 9005's up there. We're identical except for the CAs. I've got stock uppers still and Rusty's lowers currently with the RE drop brackets. In line for some JKS adjustables though. Not a #1 priority at this point. Needs some more maintenance and some new tires first.
