clean4drxj
- CT.
As far as reading here and pirate, gear deflection comes from the tubes and diff flexing. Now on pirate there is a kit to stop it but its super pricey and I do believe for 44 and 60 axles. One solution is to stiffen the axle tubes to the diff so a inner sleeve that goes all the way to the inner seal should stiffen the axle to avoid flexing.
..The tubes aren't only part of the problem, but the main reason for gear deflection is the wet noodle of a carrier(stock spicer).
So to build the ultimate HP30 I would go with JK30 diff parts(next gen) in there with a full case locker, Jana load carrying bolt, RCV's, truss&sleeved and inner C guessets ect.
