- In the islands
The XJ of 0-guage-steamer is running at the perfect temperature using a 180 degree thermostat. :read:
While it is true his system is modified, the modifications are only to help it from getting too hot. The temperature rating of the thermostat dictates only the minimum temperature at which the engine runs. It still need a good cooling system to keep high temperatures in check.
I worked in Des Moines IA for the first part of winter 2007. During those days the engine would get up to 195 degrees very quickly and remain there regardless of the speed at which I drive. My XJ have no mechanical fan so at idle the temperature will rise until the electric fans come on and pull it back down. Unfortunately, in the hot South Florida summer, the temperature stays more in the 210 degree margin,... too hot for my likeing given the under engineered cooling system thus the many complaints from drivers of the temperature suddenly spikeing out of control.
If I ever replace the thermostat in the XJ again, I will go with one that is 180 degrees since it will allow the engine to get up to 190/195 degrees and give a slight safety margin on hot temperatures.
To each his own.
To each his own.
