99xj4x4
- Bakersfield/ Chico
Im getting all my parts together for my axle swap. I have the hp king pin 60 front, 14 bolt rear w disc, 38.5s TSLs on 16.5 H1 wheels. The rear I plan to stretch slightly with a longer main leaf, but leaving the gas tank stock. I plan to keep the XJ right around 8” of lift.
So my question is what coilovers should I go with in the front? I was thinking fox/king/sway away 2.5 14”. 14+8.25= 22.25” collapsed length. My question is with 38s how much up travel am I actually going to be able to use? I can get a pretty sweet deal on dual rate 16” 2.5 Kings, but that makes the collapsed length 24.25”. Am I going to hate loosing those 2” of up travel? The other option to offset the loss in up travel is make brackets on the back of the 60 and try to get the coilovers down 2” off the axle tubes, but running the stock style 4 link w/ T&T arms space may become an issue.
Also for anyone running coilovers on their XJ what springs are you running?
Ideas for anyone running coilovers and big tires???
