Should I have the clutch fluid filled almost to the rim on the reservoir for my 96? Clutch works fine and level is about 1/4 below the edge right now. Thanks
There's a fill line molded into the reservoir. Filled to the lip is too full, because the cap has a plug that goes down into the reservoir and it will push fluid out if over-filled. But 1/4 down sounds a little low.
