- Roanoke VA
I want to clean my 90" RENIX throttle body really good before I put my motor back together and start it. If I remove the IAC and TPS can I submerse the TB in carb cleaner and soak it, or will damage the butterfly seals?
It sounds like a dumb question, but I don't want to screw up this TB.
Also any body got any suggestions on giving the EGR valve's passage a good cleaning without hurting it?
The intake is all the way tore down so its getting a good soaking now and the injectors have been professionally cleaned and tested and new rubber installed.
The RENIX head has been completly reworked and Magnafluxed, Its good to go.
