ktm racer 419
- ROW DIALIN
I measure from unirail-ground and find many XJ with climed lift heights of 5-6 turn out 8-10 ...My first clue is looking at front fenderwell and spotting a 40-tire and shock capable of about 5 or more inches of use-able up stroke .
do you go around with some measuring tape and get under everyones rig in a parking lot to prove them wrong? lol
so you posted a video of some boulders on relatively level ground. lets see some hillclimbs and sketchy obstacles.
heres my last 2 rigs for comparison. similar suspension setup, same axles, same drivetrain. different ride heights and tires.
white was 2.5" of lift (measured from axletube to the unibody rails) and 37's
black one i have never even measured the height, but im guessing its in the 5.5" area on 38's. (still wish it was lower, but i like launching it off jumps and going fast now, its a comprimise)
bonus gate at a rockcrawl comp a few years ago (only rig to drive up with it without issue, wranglers and taller rigs, either backed down, rolled, or had to take several attempts)
all the other rigs that took this line either took out the cone, or rolled.
heres a pic at ride height if you want to measure
Theres a reason all the competitive rigs in most any sport are as low as they can get away with, be it rock crawling,, rock racing, desert racing, street racing. I think you will find your rig to be much more capable if you drop it down quite a bit.
