Clayton Off Road
Clayton Off Road
- East Haven CT
Clayton Off Road High Steer Kit
This kit was designed as a great addition to most TJ,LJ,XJ,MJ,ZJ front ends. It will work with a low and high pinion D30 and D44 axles. It was designed with the average user in mind. Like our XJ, we had upgraded steering, but the factory inverted Y system has its limitations. So we designed this kit too use an individual drag link and tie rod for better on road performance. Knuckles are machined to accept RCV axle shafts and also machined for a flip kit so the tie rod is moved on top for added clearance when offroading. Kit has all necessary components to be able to use a steering stabilizer, swaybar links and be able to turn lock to lock for a great all around system.
- Improved ground clearance
- Improved steering design
- Larger brakes & calipers
- Adjustable trackbar bracket
This will work with factory axle shafts, and also allows the use of RCV axle shafts. No special tools are required to install this kit, however you will need to weld on the new trackbar mount, and lower coil bucket supports, and swaybar tabs. Here is the complete kit:
If you already have some of the parts, you can piece together a kit for yourself using our parts. We have both trusses for D30 and D44 front axles on our website, along with all the parts for our high steer kit available:
All of these parts are in stock and ready to ship out, if you have any questions give us a call or send us an email.
Alex
Marketing Director
Clayton Off Road
