POLAR_JEEP_04
- Ohio
i thought the dana 30 was a shim type yoke not crush sleeve
Oh I didnt realize they were that much money. the way people talk about them they seemed like a cheep simple part.
[hijack] which ones were which? i should know this.[/hijack]
My 96 has shims, a friend who has an 89 is also shims. I was under the impression all d30's were shims.
D30 Shims
D35 Crush
8.25 Crush
On-Topic:
The max operating angle on a U-Joint is around 5-6 degrees, and yes, YJs come with a single cardan drive shaft, and a high pinion D30 up front. At 4" the DS on my YJ is no where near the limit of the U-Joints.
You could do this to see if a single cardan solution will work for you:
Remove your front shaft and put the XJ up on the frame up front and let the front droop. With the axle drooped, take a straight edge and put it between the axle yoke and the TC yoke. Measure the angle at the TC to Straight edge. If it exceeds 5-6 degrees, you probably need to find another solution or you may bust a u-joint while drooped.
Remember what works on a single cardan shaft is equal and opposite. If at normal operating height, you can get an equal and opposite solution on the u-join angles, you should have no vibrations.
I duno, that 5-6 degree number I remember from years back.
Just rotate the C's and be done woth it.
So how much can the C's be rotated before you have to worry about the springs bowing out? I guess i'm just not sure how many degrees people usually rotate them.
So is it possible to drill/grind out the spot welds on the third member and rotate it? I was looking at mine the other day and it seems like this might be easier than rotating the knuckles and you wouldn't have to worry about the spring buckets and shock mounts being level.
Am I missing something as to why no one does this to get a better pinion angle?
