- Billings MT/Rapid City SD
someone did a stroker on here for ~1500 but I guess you would need a new everything? I don't know what else a thrown piston would screw up.
I thought you said that they said it needed hoses, belts, thermostat...etc. These things are very easy to determine...and need replaced fairly often. Without a noticeable knock....or without you asking them to check for oil pressure/compression related problems...they would have no reason to check a 89,000 mile motor for all of these things. Then they would of had to of charged you a fee for diagnosis of your engines internals....without asking for this...no garage is going to volunteer to do that. Because in the end...the customer gets mad...and says "they charged me to diagnose all these other things....and I didn't tell them to....so I'm not paying". I think it's hard to blame a shop...unless...some of the parts they installed failed...say..the hoses, thermostat, belts or whatever failed...THEN you would have a claim...I think. If you'd been having overheating problems...prior to taking it to the dealer....that was probably when you actually did the damage to your motor.xjfrancis said:It is just frustrating to know that I took it in and they put some sh!t in my car that I probably didn't need and didn't fix the problem and if they knew what they were doing I might have been able to prevent this mess.
He's at ASU - in Phoenix. "This time of year" is prime time for those bastiges to go wheeling while the rest of us freeze...been there, done that, working on the CJ in shorts and sandals in January.RichP said:The cheapest course of action would be to find a junkyard motor of the same year. ... Not something you want to do outside this time of year though.
MaXJohnson said:I wasn't trying to say you were low on oil. When the bearing spins out of position, the oil hole doesn't line up with the oil passage, so that specific bearing doesn't get oiled. When this happens, the bearing and journal heat up. The expansion due to heat reduces the clearance, causes excessive drag. The motor has to work harder to overcome the drag; hence the overheating sympton. A good stereo can help cover this up so the driver is less aware of the problem.
Yucca-Man said:
Tell me more about your oil filter mod - what did you do to get it vertical like that?
Yucca-Man said:He's at ASU - in Phoenix. "This time of year" is prime time for those bastiges to go wheeling while the rest of us freeze...been there, done that, working on the CJ in shorts and sandals in January.
Location is why I recommended the AZVJC for an engine or assistance, but which 'Joe' opened up a shop down there? Joe West, or another of 'em?
Spudboy said:I've got a twin for that engine! Mine blew at 127K, but it was making noise for about 10K before that. Sounded like piston slap up until about 50-100 miles before it went, then got progressively louder until the big bang. I was trying to nurse it along until I had time to rebuild but waited too long. I ended up with low-mile boneyard engine that worked out great.
redyouch said:i threw two rods about a year ago on 180K. for a couple weeks before i could hear rod knock. it suprises me that it blew out of nowhere. mine had two holes in the oil pan, and 2 holes in the side of the block, also the rods chopped the camshaft in half. fun huh?
xjfrancis said:so I was just driving down the highway today and POP! the car dies and I pull over to the side of the road. I get out to see what the damage was and it was immediately apparent. The puddle of oil on the gravel is what gave it away. Here’s what happened.
http://www.jeeps-offroad.com/reader-rigs/album67/IMG_1403
http://www.jeeps-offroad.com/reader-rigs/album67/IMG_1405
So I guess I have a blown engine. Funny thing is, is that I just took it into the dealership about a week ago for an overheating problem and 50 miles later my engine blows. When I took it in they said that my hoses were worn out and my thermostat was going bad and since I have no way to do my own maintenance down here at school at asu i had them fix it for about 400.
thanks Craig.
Goatman said:You haven't said how hot it got or how many times, before you took it in for repairs. These engines are very durable, but no engine can take abuse like overheating. How often did you change the oil?
The dealership might help you out as a courtesy, but they have no liability unless the hoses or thermostat that they installed failed. Did you have them change the oil at the same time? Is there evidence that there was the right amount of oil in the motor? More than likely the damage was mostly done before they even looked at it.
Exactly. If you came to my shop with your Jeep, the same thing would have happened. If you came in trying to blame us we would have sent you packing. If you were very persistant we would have you consult an attorney and ultimately our insurance would deny your claim. You would have wasted loads of time, and probably even more money.BigDawgz said:I thought you said that they said it needed hoses, belts, thermostat...etc. These things are very easy to determine...and need replaced fairly often. Without a noticeable knock....or without you asking them to check for oil pressure/compression related problems...they would have no reason to check a 89,000 mile motor for all of these things. Then they would of had to of charged you a fee for diagnosis of your engines internals....without asking for this...no garage is going to volunteer to do that. Because in the end...the customer gets mad...and says "they charged me to diagnose all these other things....and I didn't tell them to....so I'm not paying". I think it's hard to blame a shop...unless...some of the parts they installed failed...say..the hoses, thermostat, belts or whatever failed...THEN you would have a claim...I think. If you'd been having overheating problems...prior to taking it to the dealer....that was probably when you actually did the damage to your motor.
Good luck with it though....I hope you find an affordable fix for your problem.
Just my .02 cents worth
Aron
xjfrancis said:230 is the red line so I would say that it hung around 218 to 223 when driving before and after i took it in.
