Have a write up showing the late model mirrors fitted to a early model doors on my site. www.go.jeep-xj.info
To get it all to work with the late model wiring harness and ECU etc, I take it you are swapping over the dash as well then? Wont work other wise. There is also a difference in the firewall to do with clearance for the heater ducting on the later dash I think it was.
My site also shows the fitting of the later model front clip also. Are you going to swap the guards over as well so they match up with the grille surround? Just thought they were pretty trashed on the rolled one and think the early XJ were still alright weren't they? You could just reshape the corner of the surround to match the early tops of the guards which are not rounded like the later model. It is only fiberglass so easy to do.
