George2
- New Hampshire
Hoo Boy... Lift Kits can bring all kinds of suprises, can't they?
I finished my RE 4.5" lift a month ago, and I'm still working on some driveline issues (1991 Sport, 4.0, 231J and Dana 35C rear). I have a "grumble" coming from the yoke, between power/coast phases, and I'm trying to milk out major changes until Santa brings me my SYE and new driveshaft.
Things were boring at work tonight due to the holiday coming up, so I brought the Jeep into the back garage door, and changed out my rear diff fluid, since I had no idea how many times it's been changed- two colors of RTV tell me it's seen attention twice, but the "other" discoveries scared the daylights out of me.
I've ALWAYS had a "clunk" when shifting between R thru D, and I've had 2 other XJ's that had 35's, and did the same thing- but I'm paying more attention to noises now, since I'm trying to iron out some minor vibes due to a low pinion angle out back. My 6 degreee shims should be here today, so I'm just biding my time with the vibes. That will all be behind me once Santa makes the trip from WAAAY up north...
Anyway, when I pulled the diff cover I decided to put the shifter in "N", and check on where I might be seeing some sloppy meshing. What I found was that I could turn the driveshaft about 1/2". Yes, the U-Joints are NEW, due to the lift/vibe thing... Damn, it AIN't the U-Joints!
So I'm watching the ring, pinion and carrier, and they're all moving about 1/4" as I rotate the DS. It looks like the backspacing was pretty tight at some point, because both gears have VERY "horizontal block" wear patterns- the heels and heads of the gears are unworn, and the worn spaces are really clean and centered on the matching face- but the entire carrier rotates 1/4" before anything grabs ahold of the axles and idlers-
Reading up on all the ring/pinion websites and the Dana site shows me I'm in the game for ring and pinion mesh wear, but it's the idlers and the driveshaft gears that scare me- they have the ENTIRE faces worn. I searched HERE, and swept the Dana site, with no success. There weren't ANY things in the troubleshooting section that came close to what I have going on. Any new noises? Sorry, it's hard to tell until I get the driveshaft to shut up so I can listen. I have a new set of 31 M/T's, and they've been keeping the cabin in a mild rumble/drone since they went on. I can say the "clunking" isn't any WORSE that it used to be- but I haven't had time to investigsate deper.
My Primary Question:
Does anyone know how much "slop" there should/can be in a rear 35 carrier?
IS there such a spec? Does it sound wierd that the ring/pinion are good, and the driveshaft/idler gears get chummed? What "adjustment" got missed in previous services?
It's not really a HUGE issue, since I'm re-gearing both ends to 4.56's as soon as the income tax thingie clears, but it's winter in New England, and I'm hopeful I can nurse this issue gently until Uncle Sam caughs up what I over-gave him this year.
ANYBODY with rear end issues, past or present who can educate me?
Any COLONOSCOPY's don't count, but I'll admit it involves your rear end...
I'm pretty sure my own rear end gets checked more often than my Jeep has had! NOT ANYMORE!
Thanks in advance, for whatever skooling a gear-guy can provide!
