homebrew
- Bremerton, WA
Can I use square box tube to build a cage?? what are the benifits/disadvantages of using square box over round tubeing???
Newb please be gental =)
ponyracer1 said:Square tubing has a welded seam and is not the best choice for cages.
SPOBIponyracer1 said:yea yea, I figured someone would pipe up about that. ERW has a welded seam and is CRAP, buddy brought over some of that for his sliders and I'll never use it again. Full of thin spots and it was contaminating the weld from all the crap burning off. I may have just got a bad peice but I wouldn't trust my life to that sh*t.
and to provide a more uniform dimensional tolerance.kid4lyf said:SPOBI
Then he bought crap tube, probably got a deal on rejected junk.
There is nothing wrong with elect welded seamed tube. The strengths are very close (if you buy decent stuff).
EW and DOM are the same thing except for DOM being drawn through/over a die after it's welded.
The main purpose of this is to eliminate the seam on the inside for honing/fitting, not for added strength.
cagedxj said:I use 1 5/8" .135 ERW. It was just a carry over from my drag racing days. If it is good enough for 200+ mph crashes it will...and has worked fine for me.
If you don't mind Brett, please elaborate on why square tube should not be used ... just to satisfy my curiosity. I know, asthetically, it would not be prefered, but ...BrettM said:can you? yes.
should you? no.
F=MAXJ_ranger said:well race cars are designed to be lightweight, not have 1/4" thick plating on the bottom, 400 lb bumpers, 1 ton axles, coolers, camping gear, and whatever else in them...
comparing the two isnt worth your time...
asthetics is certainly a large part of my reasoning. also, I have no doubt a safe cage could be made from square tube, but all the mitered and welded corners create many more potential weak points. much of my reasoning also comes down to the whole "if you need to ask, then the answer is no" thing, since people that need to ask about this generally don't have the knowledge to execute it properly.LBEXJ said:If you don't mind Brett, please elaborate on why square tube should not be used ... just to satisfy my curiosity. I know, asthetically, it would not be prefered, but ...
Thanks ...
Les
BrettM said:asthetics is certainly a large part of my reasoning.
feel free to disagree, but I like the way my MJ looks.cracker said::laugh:
Yeah right. Like you ever had a concern for that.
