- Hammertown, USA
The stock carrier will flex, allow the ring gear to deflect and initiate ring gear failure.
.. thats more or less what I have to say on that matter.
I have built up a D-30, my old 30 has served me well on 35's but its just a matter of time.
The new axle has;
Longfield Superaxle shafts
Yukon R&P 4.88's
Aussie Locker
RuffStuff cover
Home made truss out of 2"x4"x3/16" box.
I hope to get it installed in the next week or so. Here is a pic, all work, including the gear set-up was done by me.
why not run the thick gears for the D30 VS. a larger carrier? wouldnt this make them stronger and take a bite out of the slippin gears problem from the D30? ive been debating on this also... i bout a 04 WJ for the motor (for a 2000 0331 head) and kept the knuckles and all for my XJ... not installed yet but theres a dang D44 on CL built ready for a XJ for $900 with gears, lockers, and all... i actually come across them often on there as alot of people swap to D60's... ive just been debating on selling my D30 and stuff with it and going D44... but seems like the killer between the 2 is the ring and pinion... which i would think thick gears would take care of... my plans are 3.5 to 4.5 of lift and 37's but i dont want to go wide... and my XJ's gutted and chopped so less weight to strain the axles... guess what im asking is wouldnt Thick gears be stronger and possibly even take care of gear slip issue in a D30?
Which is already the weak point of the 30... Okay- Full carrier it is then. Thanks... I may do the lunchbox as a temporary measure (I need to wheel), but will go ARB asap. I really cannot do another Detroit, that incident left a really bad taste.
...our buddy on here rob wheels his trussed 30 with stock shafts, 4.56s and lockright and 37's and beats the piss out of it most weekends of the year up at the con or fordyce...
I was thinking the same thing.I guess your idea of "beats the piss out of it" is different than mine.
That is the game you play with almost any axle, "move the weak point around". I think I'd have to disagree with you on the "rather blow a R&P than a ball joint". A ball joint (assuming it doesn't take out the knuckle or C) is a pretty simple replacement. Sure, it does take some time and can get annoying at 11pm at night on the side of a hill, but it is better and cheaper than a R&P breakage. Especially for some of these guys that don't gear there own stuff (nothing wrong with that).Eventually ... the weak point is going to move somewhere else. But I guess I'd rather break a R&P or ujoint, as opposed to a balljoint. I would still be able to drive home with a dead R&P or ujoint.
Joe
...our buddy on here rob wheels his trussed 30 with stock shafts, 4.56s and lockright and 37's and beats the piss out of it most weekends of the year up at the con or fordyce. still holding strong.
I'm with Joe here. When I'm stuck on the trail at 11pm on Sunday night, tired, cold, hungry, and I have to be at work 200 miles away at 6 this next morning.. I would happily pay the cost of gears+install to not be sitting there trying to hammer my spare balljoints in.
Please ... do not agree with me. I'd rather be the odd man out. :rattle:
See ... my logic is different. Most times that I've seen .... a grenaded balljoint leads to inner yoke or knuckle damage. And that REALLY stops you in a hurry. I'd rather not have to replace the balljoint/knuckle/etc at 11 pm on the side of the hill. Not everyone remembers to carry spare balljoints around either. I don't trailer my Jeep ... so I want to make sure it gets home safely and smoothly. So if I blew the R&P ... i unlock the hub and go home. If I destroy the shaft ... I pull it out and stuff the tube with a rag and go home.
You both make good points. There are a lot of "ifs" in the above scenarios. However, if a knuckle or C is damaged, I'd have to agree with you.I'm with Joe here. When I'm stuck on the trail at 11pm on Sunday night, tired, cold, hungry, and I have to be at work 200 miles away at 6 this next morning.. I would happily pay the cost of gears+install to not be sitting there trying to hammer my spare balljoints in.
I play nice. :cheers:Nothing wrong with your opinion -- I was just clarifying mine better because you forced me to. :cheers:
Cal, I've seen your axle pop up in numerous threads, but I don't think the question has been asked (or I missed it). Would you drop that kinda coin on a D30 again?
How often has a balljoint failed to the point that it came apart?
