mikedashg
- San Diego, CA
Dunno how you bent yours like that, but clean off is usually the case. Mine ripped off on the trail. Bent my upper arm and shock from the axle moving backwards and wheeling on it.
userbmx1315 said:how did you manage to bend it that bad? i rolled my old jeep 3 times and bent both mounts and it wasnt that bad. great fix. looks like the rough country arms.
ratherbcamping said:Yep, The D30 I bought recently has some good battle scars and it has the little skid plates on the brackets. I took these before pictures. You can see that one side was completely re-welded in place.
I have already straightened out the brackets. Next I will grid down and clean up the existing welds and re-weld as needed. I plan to weld washers on the outside of the brackets, fill in the existing holes on the inside, grind smooth and drill the mounting holes to the correct size. They are oval shaped and pretty worn out right now.
TRAILREADYXJ said:I've seen quite a few of these get bent up pretty bad, and even rip off the axle. The worst of them were using fixed arms with poly bushings and no flex joints. This adds a lot of stress when you over flex it, and the stock mounts just can't handle it.
goodburbon said:Sorry about that. There was no way to properly prepare the surface and the machine that we had available was a 110 volt fluxcore unit that wouldn't start a bead for anything. I finally got one good bead going and the machine tapped out after 5 seconds. I advise that those welds be taken all the way down because I did not get good penetration for most of it, just a pile of upside down crap.
lowrange2 said:Lol... The rust doesn't wait til next weekend...
