Rivera1833
- Stafford, VA
If you want to know about Edelbrock's on an XJ lift, check out this build.http://www.jeepforum.com/forum/f177/my-2000-xj-build-647056/
those LCA are poop...
youll see that most have a bend in them or the tubing is offset to the bottom of the axle side joint to add clearance. this is because on droop, strait arms will hit the coil bucket/shock mounts and limit droop. if this isnt an issue for you, then fair enough.
the length should be fine.
xj's with ax15's have 3.06? gearing, and it's horrible with 31's. you pretty much have to stay in 4 low off road, and slip the crap out of the clutch to do any real crawling. it's a PITA to wheel. i'd change them out for 4.10's or 3.73's.
i have the exact same jeep as you, with a 4' lift and 31's, no lockers/lsd, and i dont think i want to wheel again until i get the gears swapped.
I have to disagree with you on this one, my Girlfriend has around 4" of lift, 31" Falken Rocky Mountain ATS' (on Ravines), stock gearing (3.07 or 3.09 or whatever) on her 98 with an AX15 / NP231 / D35 / D30 / Open front and rear.
It actually does pretty damn well offroad, it has surprised me more than a few times on what it can do. I don't own a manual, but I can operate one, and it's no harder to drive her Jeep offroad than onroad as far as the clutch / gear-changes go.
She does have an almost brand new clutch I installed at the end of last year though...
if you're not having issues with the gearing being too high then you're not doing the same difficulty of terrain that we do. there's no way to make it up some of this stuff without slipping the clutch, the engine will stall. also, good luck wheeling behind someone with proper gearing.I have to disagree with you on this one, my Girlfriend has around 4" of lift, 31" Falken Rocky Mountain ATS' (on Ravines), stock gearing (3.07 or 3.09 or whatever) on her 98 with an AX15 / NP231 / D35 / D30 / Open front and rear.
Forgot to mention shocks,bilsteins are very nice shocks,problem is not everyone can afford them.Doetsch makes a jeep specific shock(Baja Ryder)$52.00 ea.slap a boot on them and there warrantied for life.best bang for buck shock on the market or you can find another less expensive shock.The best lifts are pieced together with various components. slow down and think it through. buy some 3" coils and a decent set of leafs,ome's are a good compromise.an adjustable track bar is also a wise investment IMHO(inchitis). you need some LCA's also,there's reasonably priced one's out there or used. extend your front brake lines by moving the mount and the rear brakes can be extended with a aftermarket bracket and don't forget sway bar disco's. again take you time,slow down and collect everything you need and do it right.
Clean4drxj: Could you describe a bit more about what you don't like about zone products?
I'd prefer not to go the ZJ V8 springs / bastard pack route, because I'd like a spring rate designed with my lighter 4.0 Cherokee in mind, and I really can't stomach spending $1000 to lift a $2000 Cherokee...
I'm really not concerned about it. I've been trying it lately with the 31's on the rear (around town / hwy 2wd only of course) and it's not bad at all - plus it's seemed to have actually helped with my combined mpgs (as I'm more hwy than city lately) and it still took an early 90s V8 Auto CamaroDriving will probably be 40/40/20 (City/Highway/Off-Road). With very little crawling, and mostly just forest service roads and such for the off-road portion.
